I tried PMing you this, but it says you chose to not receive PMs.
Rewire headlights back to factory and replace bulbs with OEM watt bulbs. There is a factory service manual here on the forums you can download.
Shouldn't be too difficult.
I know that when you add LED turn signals, you must have an inline resistor or they won't work. So I think your headlights (LED) were not designed for that system. You would have to wire BOTH headlights back to stock. If you haven't added anything else, like a cell phone charging port, etc, you should be good after replacing the fuse.
