1 - 5 of 5 Posts
my speedo is jacked up, its real jerky and sometimes it gets stuck, like i may be doing 65 and it will jump up to 150 and just stay stuck there, its cycles fine along with my tac when i turn the key on, thought it was my speed sensor so i bought a used one last season, didnt change a bit.... thought it may be another bad one so i just tried another used one and they all are the same, jerky and sticky. also when i remove them there is oil on the end that goes into the crank case, is that normal? i would really like my speedo to work properly any ideas? BTW i cleaned all connections with contact cleaner on all 3 of the different speed sensors i have installed.
Discussion Starter #2
speedo
i made a little video so you can kinda see how its jerky or jumpy, but you can notice way more when riding while slowing down and speeding up.
Man that is weird.Can you borrow the same year ecu to test with.
i dont know anyone else that has a bike like mine around here, is it normal for oil to be on the part that goes into the crankcase? i would think it is. i dont really think its the speed sensor anymore... unless i got 3 bad ones in a row.
I would check all wires and make sure none of them are touching. After that check your throttle cables. Here is a wire diagram of a 2003 that works for me and came in handy plenty of time
1 - 5 of 5 Posts
