1 - 1 of 1 Posts
When I bought the bike the fuel pump would not cut on. So I checked the power going to the fuel pump and it was cutting on showing that it was priming. So I assumed bad fuel pump. Replaced it and clean the tank out. And sealed it with a tank seal kit due to rust. At some point the pump started to work as it did not initially 🤷🏻‍♂️. So I assumed a relay became unstuck or something. A few weeks later same problem. Turns over fine. No pump priming. But the wires going in show it cutting on and priming. (No noise. No start) please help. This sounds like a common Problem but no solution that I can find.
1 - 1 of 1 Posts
