41 - 60 of 89 Posts
Discussion Starter #42
Back from SS powder coat. They did a great job. Smoothed the frame out beautifully.
now to get this hole plugged.
Discussion Starter #47
Graves provides a high quality shock link and dog bone. Billet.
the captured nuts are a nice touch.
the Graves link will provide more leverage.
Going to need a heavier spring I think.
Discussion Starter #51
who's doing the calculus for the shock geometry and frame-swingarm relationship?
Me....lol
I have access to a 2010 Yamaha R1. So all the measurements for the R1 arm came from that. Oem set up. Swingarm angle, ride height, rake and trail. All very conservative.
One thing that was interesting is that the shock was almost straight up and down.
The graves link helps put more shock angle into the suspension. And on R1s requires a stiffer spring.
When I had the 12 frame/10R forks and R1 arm mocked up, its in the ball park of modern Sportbike specs.
But I will need to tweek. So I have assembled
a few components to help me get to a good baseline. Only had empty cases and a empty head hung in the frame. Will need the complete engine to finalize a baseline. I have
a few dog bones. Made a few top shock perches. And drilled a extra hole for the shock rocker link.
This currently gives me adjustability for shock angle, shock height, swingarm angle from 0-13° with multiple shock height locations. With full shock travel.
This is interesting, Im curious how it will perform after all those mods. Did You weight rear swingarm? Is 12 a heavy one, or even with comparision with modern bikes it still can compete .
Discussion Starter #53
The main issue to get around is the swingarm pivot shaft. The 12 has a one piece 25mm dia threaded shaft.
The R1 is 22mm.
The big threaded ends are also different sizes from 12 to r1.
here’s pics of the R1 shaft.
the 12 frame is not threaded for the big end.
12s use a threaded adjustable collar on the inside of the frame. The R1 has a threaded frame.
I have from a earlier project a zx14 pivot shaft ( 20mm) and a threaded slip on collar that I made.
Discussion Starter #55
I used all of the oem R1 swingarm bearings and pivot shaft tube. I bushed the pivot shaft tube to fit the 20mm zx14 pivot shaft.
then I tighten the pivot shaft using the zx14 sequence.
This thread is awesome!!
I'm learning shit that I don't understand - Makes me feel funny - But I like it!!
Seriously - Cool stuff!!
(y) (y) (y)
Discussion Starter #60 (Edited)
B model steel triple clamp nut on the left. Aluminum Gen5 nut on the right.
B model 12 seal fits perfectly.
little stuff like this everywhere helps to make the modern bikes lighter.
41 - 60 of 89 Posts
