1 - 20 of 20 Posts
Hi! I shall install a 12volts cig lighter female on my bike, on that I shall be able to connect GPS and an accelerometer to measure 1/4 mile times.
Where shall I take 12volt? which cable? Is there a "free" fuse somewhere?
Be glad for help, I don´t have a servicemanual with wiringdiagram here!?
Mikael from Sweden, Green 2001
Discussion Starter · #3 ·
Do you have a volt meter?? If so, just splice in anywhere you can find 12 volts (making sure that you splice BEFORE the fuse as not to draw too much apmerage through the fuse). You should be able to go to your local auto parts store and simply buy a fuse to put inline of the "lighter" that you are splicing in.
<font color="0000ff"><marquee>WWW.InsaneCyclePosse.com</font color="0000ff"></marquee></p>
In your fuse box there is an open slot for accessories. One side is hot and the other has no wiring coming form it. You need to add the extra wire and fuse yourself but when finished you will have a 12v output with fuse and it won't interfere with any of your other stuff. Currently I am running a Radar Jammer and strobe lights and it doesn't pull more than 3 amps so judge your fuse size accordingly... Good luck.
This would be a good thread for a picture of the fuse box and a pointer to the accessories fuse that people can use.
Does anyone have the ability to take a pic, I can draw the graphics on the pic if you email it to me and let me know the fuse that people should use.
[email protected]
www.ZX-12R.org</font>
Top 100 Bike Sites</font></p>
I've got the bike apart and my new Olympus digital should be here Tues. or Wed. of this week. Let me know if you want me to burn a picture of the fuse box.....
That would be great. I looked at the fuse box at one time, but didn't notice an accessory fuse. However I wasn't looking very hard. If you find the correct fuse, it would be great to somehow mark the hot side that someone would hook there detector or ?? to.
Thanks for helping out,
Easyrider
[email protected]
I hard wired in my Chatter Box and just spliced into the "third headlight" (that little light above the headlights) wiring. Was easy to get to (right behind the gauge cluster) and easy to hide the wiring.
I also "hard wired" my Chatter Box push-to-talk button into the 4-way emergency flashers. Works great and is a super clean install.
Any one else have some trick wiring they have done?
<img src=http://www.ezboard.com/intl/aenglish/images/emoticons/glasses.gif ALT="8)">
I'm wiring in a separate electrical system/fuse box. It has 3 key on circuits and 4 switched circuits. One pos wire from the battery to a 40amp automatic circuit breaker and from there to the unit. One ground from the battery to the unit and one keyed pos wire to the unit to energize the relay. I want to protect the stock loom from the N2O solenoid drain. Pictures of work in progress on the Yosh high mount thread.
Discussion Starter · #13 ·
ckarlewics, I would really like to see that push to talk
setup you have. If it's not too much trouble I would like
to see pic's.
TENN12,
You bet! I will have to borrow a digital camera and take some pics. I will get working on it. I'll borrow a camera from work and get some pics posted ASAP.
<img src=http://www.ezboard.com/intl/aenglish/images/emoticons/smile.gif ALT=":)"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/smile.gif ALT=":)"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/smile.gif ALT=":)">
</p>Edited by: <A HREF=http://pub56.ezboard.com/uckarlewicz.showPublicProfile?language=EN>ckarlewicz</A> at: 12/10/01 8:57:48 pm
Thanks guys, a pic or so will really help this thread out. I am sure everyone will need to know this information sooner or later, whether it is for a radar detector, GPS, etc.
Thanks,
Easyrider
[email protected]
Okay...here they are.
First, here is what it looks like all installed
This is what the inside of the handle bar assembly looks like.
And a close up of where I tapped into the "third headlight" for power to the Chatter box so that I never run out of battery.
And last, but not least, where I wired the yellow box in at the speed sensor.
I will post how to wire into the hazard switch later. Got to go to work now! <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/smile.gif ALT=":)"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/smile.gif ALT=":)"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/smile.gif ALT=":)">
</p>Edited by: <A HREF=http://pub56.ezboard.com/uckarlewicz.showPublicProfile?language=EN>ckarlewicz</A> at: 12/12/01 2:58:02 pm
Discussion Starter · #17 ·
Nice set up. How hard would it be to wire the P.T.T.
button into the horn?<img src=http://www.ezboard.com/intl/aenglish/images/emoticons/happy.gif ALT=":D"> I never use the horn anyway,
I use my exhaust as my horn.<img src=http://www.ezboard.com/intl/aenglish/images/emoticons/happy.gif ALT=":D">
The horn would be even easier, because you would not have to disassemble the switch. With the hazard switch, you have to disassemble the switch and remove a pin that makes the switch lock in either the open or closed position. No such problem with the horn switch. Just remove the wire going to the horn and solder on the push to talk wire!
</p>Edited by: <A HREF=http://pub56.ezboard.com/uckarlewicz.showPublicProfile?language=EN>ckarlewicz</A> at: 12/13/01 3:00:58 am
Great job at documenting your work.
Not to be too picky, but, is it possible to get a pic of where you wired into the fuse box? It would round out this thread for an nice archive.
Thanks
[email protected]
1 - 20 of 20 Posts
