1 - 10 of 10 Posts
I just got a 94 zx11 with a blown head gasket
And for some reason it acts like its in neutral
When it's in 3 and 4th gear. So I am wondering w
What engine and transmissions fit the 1994?
Also does somebody know where I could get them
For a decent price?
split the case`s and strip it down to get a look see.How many miles on that puppy.
It has 34000 mi on it unfortunately it only has 90
Psi of compression across the board and I am
Not familiar with motorcycle engines like I am with
Automotive so I think I should probably replace it unless
There is another reason other than rings thAt would cause
Readings like that .
Thanks for the advice it is appreciated
So my next question is does anyone know where I can
Get an engine /transmission for a zx 11 d for a reasonable
Price
You're about to spend a $1200 on a used motor in unknown running condition?
Why not address the headgasket & build-up the motor you have?
Familiarizing yourself with your bike should be your top priority.
You know.. in case you breakdown somewhere outside of BFE.
If you can work on a car, you can work on these engines.
Some fckers act like its a black art.. its not.
all you need is..
FSM
TOOLS
PARTS
BEER
(some four letter word combinations)
ps- i have shelfs of parts.. i think I have a ZX/ZZR-D trans if you're hard up..
Cheers!
do not trust those lying motherfuckers on flea-bay.......don`t ask me how i know........Has your engine been run real hard as in worn out valve seats mushroomed.If the head still spec`s out by all means refurb that engine.It can go 100k easy if you don`t race it.
^ +1
:thumbup:
Fix it, and make it mean. :evil:
+1.
1 - 10 of 10 Posts
