Hi all. Are there any other fan switches which fit the A1 radiator or does anyone know the thread size?. Mine has gone open circuit so needs replacing. i will be fitting a manual switch in parallel as well ( want both just to be safe)
its m16, but i dont know the pitch off hand
the 02 and newer are 18mm, same as most o2 bungs. the older m16 ones are harder to find replacements for :(
i just checked an order i did a couple yrs ago where i had purchased a cheap m16x1.5 fan switch that was supposed to turn on at 82-87C (zx12r is 93-103C). it fit perfectly, but the chinese didnt have their temps correct as it turned on when the temp gauge started blinking. its possible an oem sensor and not a cheap copy would work as its supposed to. the add listed these models that it fit. i havent revisited it since, just did the manual switch.
MARUTI
800 0.8 796CC 26KW Saloon 1991-2006
SUZUKI
ALTO I (SS80) 0.8 797CC 29KW Hatchback 1983-1985
ALTO I (SS80) 0.8 (SS80F, SS80G) 796CC 29KW Hatchback 1982-1985
Q
Autozone part sw524 life time warranty. $41.76 will turn on at a lower temp too. I installed 6 years ago. I think I have to hot rod the connector.
Q
Says made in Italy
