1 - 13 of 13 Posts
Anyone have one of these to sell? I need one. A new one would be super fantastic, but probably impossible. Anyone?
CMG,
Thank you for the pics. I believe that is a bit rougher than what I am looking for, thank you again.
No, I haven't considered it. I suppose the Rev limiter would be the best part if that. Are there other benefits?
CMG,
Scott can add timing where you want it. If you use a muzzys timing rotor then you advance the timing everywhere. You only need alittle more timing mid-top end. He can do this. Raise the rev limit too. You should at least check into it.
He doesn’t cut anything either. It’s a true flash.
I believe he is the only one doing the 2000 A1.
Thanks for the info, might check into that.
Thought about getting the Ignition Module from Dynojet.
Can anyone tell me how much of a difference this makes on a stock bike with full exhaust, k&n filter and a PCV?
Dimm,
Are you having a problem? If you're not then it's probably not worth installing one. It can help with low speed throttle response and roll-on response issues, it did on my bike with similar mods. Don't expect a power gain that can be felt. It's a set advance across the whole rev range. Dave Potter had a thread on here outlining how to modify the stock ignition timing by moving the tick mark sensor. I think it would give about 4 degrees of advance. I have my Muzzy advancer set at about 3.5 degrees because of a post on here at the time that said dyno testing showed power tailing off at high RPMs with an advance of 4 or more degrees. I have BMC race filters, a PCIII USB and run the Dynojet map for a Yoshimura full system. The only change to the map is +2 fuel #2 cylinder because the header was glowing sooner at idle than the other three, before the fans turn on. Never have seen the need to have a dyno tune since it runs so well. The exhaust is always a nice shade of brown no matter how I ride it. I can run it at 25 mph in 6th and it pulls cleanly when I roll it on. I'm the original owner, it's a 2003, did all this in 2006.
  • Like
Reactions: Dave Smith
1 - 13 of 13 Posts
