2001 Concours
Evening all. I had a leak on my tank on my 2001 Concours. Found a used one on EBay. Ever since installing, unless I open the cap after riding, I get gas running out of the air cleaner. When I do open it, the tank is super-pressurized. I'm assuming there's an issue with the tank vent. I'm not sure if I need to check vent lines or replace the cap. Any help is appreciated!
Hi I have had a couple Gtr1000s same issue pull the cap apart pull the rubber vent out.put cap back together without rubber disk of the vent forget never have problems again.
2001 Concours
Discussion Starter · #3 ·
Could you provide more insight on this? When I open the cap, it looks like there’s only one rubber gasket and it basically holds the entire locking mechanism together. I’m a bit confused. Thanks!
