Hi guys, Is there anyone in the UK that can flash the ecu on my 2001 zx12r?
Hi cmg I already have a mtc can on without baffles but I'm looking to get full decat system so want rpm raised and make sure there are no engine management lights on.What do you want done to the ecu? Raise the rpm, coil dwell, timing?
Scott can do the fuel tables, but that is something that will require the bike and dyno time. I don’t believe he has a file of different fuel tables to flash.
Will the fi light not come on? Plus if I put a full exhaust on Will the fueling/throttle response be affected?Scott can do that for you. If you change to a full exhaust, there are no engine management lights or codes that will be effected.
Hi Scott, if I sent you my ecu what would you be able to do to it? I'm looking for improved throttle response and the rev limit increased. More power if possible. Who doesn't want that lolHi, if you cant find someone, i ship worldwide.
