Just put in a new stator (Rick's Electric p/n 268359).
Alternator Output Voltage Check:
AB and C leads are putting out around 67 vac each and are pretty consistent as I revved up to 4000 rpm.
Reg/Rectifier Output Voltage Check:
Plugged stator connector to volt/reg connector. With engine running from idle to 4000 rpm, output voltage stayed around 13.6 vdc.
Thermal Check:
With engine running for 15 mins, stator lead wires were getting up to 126 deg F at reg/rectifier connector. Reg/rectifier was getting up to 186 deg F.
Is all this normal, or do I have an issue somewhere?
Good question I've never checked mine, I do have an infra red heat gun so next time I power mine up with the seats off ill check but when that will be I don't know.
186 degrees f seems a bit hot for the RR... And I don't get any heat from my wires now that I've eliminated the plug and straight soldered the wires...
Thanks Ninjayorkie and Perfecte99,
I'll try removing the plug and solder the wires. Hopefully that'll help.
Hi it is indeed a good idea to remove both of the connectors and solder the wires in place just for peace of mind Craig
Discussion Starter #6 (Edited)
Soldered wires together at stator/Regulator plug. Thermal tests resulted in no change. Stator wires were getting in the 120's (deg F) and the reg/rectifier was at 176 (deg F) when I shut the bike down.
Was I supposed to include the 5-pin connector, as well?
Eliminated standard connectors by soldering the wires together. On a 30 minutes ride, the wires reached up to around 125 F. Not bad. My Regulator/Rectifier got up to 240 F.
Does anyone know what the expected heat range for the RR should be?
