1 - 13 of 13 Posts
:eek: i just picked up an 03 swingarm to convert my 99 zx9r what else do i need to complete the conversion ? will the 99 shock and linkages work ??? thank you all in advance :eek:
I think you might be in virgin territory there, but I would be really curious what you learn. I know they changed the linkage ratios, but as far as parts interchangability, I have no idea.
Also, my bike ('98) has small axles. I have seen a few '99's with large axles and a few more with the small ones. You will definately need the large axles.
Good luck. Let us know what you find out!!
PM danno,he did it to his 2000, I don't think you can do it to a C model but I'am prob wrong...
Also the shock is different
Yeah, if the swing arm works you are still going to need a rear shock assembly from an 02' or up unless you get an after market designed for 02' and up which will cost you more.
John
I dunno about putting the 02 arm on the 99 but it'll work with the 00-10 models with no issues. You will need the 02 shock though... I've had mine on for 2 years now with no issues..
Sunshine
you will need the rear shock because the resivor on your shock won't fit.
I have an 02 shock and swingarm if anyone is interested let me know.
you can feel a big difference with the braced swingarm as you start to slide your ass off of the seat you can really tighten up your corners.
:eek: hey Danno how about the linkages and the axle will the 99 parts except the shock work ??? thanks :eek:
I did my swap on a 2k and every thing else swapped over. If anything I would think you may have issues with the rear axle or spacer size because of rim with been changed from 99 to 2k. I'll do my research for you if I get a chance today and l will get back at you.
Is the '02 shock a remote reservoir or? I have an Ohlins with adjustable ride height, so I was wondering if it would still fit with the '02 swingarm.
thanx
no, the 02 resivor is mounted in a different direction. I think your Ohlins setup should work, but don't take my word on it.
Discussion Starter #11
thanks Danno :eek: some of the race guys were saying just to cut the brace off and re weld it on the 99 swingarm . What do you guys think of that ?????? :eek:
thanks Danno some of the race guys were saying just to cut the brace off and re weld it on the 99 swingarm . What do you guys think of that ??????
I wouldn't recommend it unless you have experience with welding aluminum and have some sort of fixture to keep it from warping from the heat. The hot set up for, I beleive the 92 Honda CR250, was to stitch weld an 1/8 aluminum plate onthe inside of the swingarm to stiffen it up. This worked, but it made getting the wheel on/off a real pain because of some distortion.
Discussion Starter #13
I wouldn't recommend it unless you have experience with welding aluminum and have some sort of fixture to keep it from warping from the heat. The hot set up for, I beleive the 92 Honda CR250, was to stitch weld an 1/8 aluminum plate onthe inside of the swingarm to stiffen it up. This worked, but it made getting the wheel on/off a real pain because of some distortion.[/quote
:eek: our shop have some sort of a jig made up or we'll just make a swingarm jig :eek: 8) after all isn't this what the fun's all about :D thanks
1 - 13 of 13 Posts
