1 - 2 of 2 Posts
2014 KAWASAKI VERSYS ABS
A Multitalented Middleweight Motorcycle with Added Confidence!
The Kawasaki Versys ABS is a rare exception to the old adage, “jack of all trades, master of none.” This motorcycle’s relaxed riding position makes it ideal for daily commuting, while a Ninja-like sporting spirit lets it tackle serpentine roads with the competence of a hard-core sportbike. Its efficient 649cc parallel-twin engine and overall layout also make short work out of covering long distances. With the addition of ABS brakes for 2014, Versys really is a jack of all trades, and it truly masters the art of being a great motorcycle!
Versys’ adaptable personality is greatly enhanced by the rubber bushings on its rear engine mounts and rubber inserts atop its footpegs, which isolate the rider from engine vibration for all-day comfort. This flexible nature carries through to the Versys’ edgy upright sportbike styling, which incorporates an adjustable windscreen to accommodate taller and shorter riders alike.
Versys’ compact, liquid-cooled, fuel-injected, 649cc, parallel-twin engine was the perfect powerplant for this light and nimble do-anything bike right from the start: it’s lively enough for aggressive sport riders and predictable enough to inspire confidence in every-day commuters. The torquey twin delivers a deep ribbon of power in the lower and middle parts of its rev range, making the Versys a great commuter and relaxed traveling companion. Its surprising genius becomes readily apparent once the roads turn twisty, because despite its comfort and civility, the fun-to-ride Versys also offers genuine sportbike handling and excellent fuel economy. With its big, 5-gallon fuel tank, you can go a long way between fill-ups.
Long-travel, high-tech suspension is critical to the Versys’ multi-role mission. A Showa rear shock with two-stage damping firms up progressively as the wheel moves through its stroke, providing an initially plush ride that firms to near-sportbike levels as suspension loads escalate. The bike’s short, compact engine makes it possible to use a longer than average gull-wing swingarm to reduce throttle-induced suspension movement and excellent handling. An adjustable, long-travel 41mm tapered-tube inverted fork soaks up bumps big and small, and like the rear end, firms up nicely as the pace increases.
Crisp, linear ABS brakes are new for 2014 and help minimize drama and make slowing down a simple affair. Those new anti-lock brakes also boost the Versys’ already impressive versatility by reducing rider anxiety when conditions are questionable.
Absolutely key to the Versys’ success is a comfortable, carefully designed cockpit that provides a mostly upright, natural seating position and features a stepped seat constructed to provide optimum comfort for both rider and passenger. The comfort theme is further enhanced by the adjustable windscreen, which offers three different positions. An easy-to-read and informative instrument panel allows riders to quickly scan the gauges and keep their eyes on the road. Possibly the most versatile motorcycle out there, the Versys excels at almost any task it’s given, from gridlock traffic jams to canyon carving to long-distance touring.
2014 Kawasaki Versys ABS
Features and Benefits
Key Features
NEW ABS brakes offer excellent performance and enhanced confidence in adverse conditions
Amazingly versatile motorcycle is exceptionally comfortable to ride in a variety of situations, from commuting, to backroads, to touring and even track days
649cc parallel twin with digital fuel injection (DFI®) provides smooth, responsive power
Long-travel fork delivers excellent performance over a wide range of situations
Adjustable single-shock rear suspension offers progressive damping as suspension load increases
3-way adjustable windscreen allows customizable wind protection
Aluminum swingarm and 17-inch cast aluminum wheels reduce unsprung weight for better ride quality
Under-engine exhaust promotes better weight centralization
Aggressive styling gives the Versys a distinctive look...
Follow this link for the Full 2014 Kawasaki Versys Specs.
1 - 2 of 2 Posts
