5 gears on my zx 12r
443 Views 7 Replies 2 Participants Last post by  bikerdude02
I have only 5 gears on my zx 12r a1 I bought the bike this way dous anybody else have 5 gears?
1 - 8 of 8 Posts
The 12 only came with a 6 speed box. If a gear is missing then something is wrong with the gears or gear selector mechanism. Do you know which gear isn't there?
yes i am missing 6th gear
can u give me any tips i have the 2000 a1 usually hear problems with first and second gear not 6th
I'd start with the easiest area to access. Pull the clutch basket and you can access the gear change mechanism. If you get the rear wheel off the ground and spin it by hand, you can work your way through the gearbox. Have a look at the gearchange mechanism for a reason why you're missing a gear.
Out of curiousity, what happens in 5th, when you try to shift into 6th? Are you getting the full shift movement, or is it solid, ie no movement when you shift?
  • Like
Reactions: 1
ill get back to u on that ill have to put a couple things together to ride
Ok so when I try to shift into 6th gear the shift lever does not move at all does that mean anything or give any clues on my problem
It suggests that when you're trying to shift, something is stopping it, rather than not engaging somewhere. My suspicion is that you have a bent shift fork, but as I mentioned before, start by removing the clutch basket and check the shift mechanism. If it's not the shift mechanism, then you're into engine out territory and splitting the crankcases.
1 - 8 of 8 Posts
