Hi! My names Aaron and this is my first post .. Ever so here's my issue.. I have the 77 kz650 c model .. And I restored it back to life iv replaced ignition coils, ignition points and condensor, I've checked rectifer and regulator and it was charging at the time the bike WAS running.. So anyways I decided bike runs real good (drove 200 miles) but small hesitation at take off so i decided to sunc carbs with vaccume gauges and to my surprise they were way off.. So anyways my point is I started adjusting when bike warmed up it took a long time but I eventually got it I though then bike would Idle but not by itself if I didn't give throtle (ran real good and responsive) but it dye so I figured I'd take a break for the day do the next day same thing but real real hard to start ! Finally got it but ran so bad popping from exhaust and carbs.. So now my bike won't start at all I checked plugs they looked a little black but not to bad so I replaced then still no start it sounds like it want to but no go then I checked voltage its good 12.7v so I pulled plug after several attempt of kicks tarting and found plugs s little wet with fuel (normal) so I'm thinking spark issue? But I pulled plug and kept it in spark plug wire and it sparked maybe weak not sure so Im really stumped to what it could be.. On another note when I pull throttle while kick starting sometimes it will fire up real quick for a sec then pop out of exaust and carbs and die throttle wont help ?? I'm stuped I know the three major components air/fuel/spark I beleive I have fuel and iv cleaned carbs.. I also have spark (maybe weak) and air I don't believe it cause this stubborn issue iv even tried spraying starting fluid nothing? Please help sorry for long summary
