<blockquote>Quote:<hr> I'm not knocking the PC3R, but I am saying that if you have everything else dialed in spot-on, the stock ECU will do just fine with a modded 12r.<hr></blockquote>
How do you know you have everything spot-on? Have you put it on the dyno (run it through its range at 20, 40, 60, 80 and 100% throttle) to see what the A/F ratio looks like? Or are you using your seat of the pants dyno to base you judgment on?
I suppose one could say the same about a carbureted bike - the stock jets and needles would do just fine if everything else was dialed in spot-on. But in most cases a little rejetting will be called for if you add a new pipe to the bike.
My bike was still quite capable off pulling the wheel off the ground, but it still ran like shit.
Because of where you live you may have gotten lucky... I don't know. You may know something I don't. I don't know your situation. The profile of the stock ECU may be adequate for you area. Of course it's possible that another 12 in your area would not fair as well - as I've said, no two machine are exactly alike - same model or no....
I will say that for me, here in the Cincinnati area I've found that with just the pipe the bike ran like crap - after the PC install and custom map the bike runs great. I don't know of any other/easier way of dialing it in than using a PC to make up for the changes caused by adding an aftermarket pipe... If there is a better way, then I admit my ignorance...
If you want to go without a PC, then I would still have it dyno'ed to see what the A/F ratios look like, even if the bike seems to run good. You never know, you may find that after examining the results and making some adjustments the bike can run even better. If you have it dyno'ed at least you have a pretty good ideal of where you stand and if any tangible improvements could be obtained. Then you would also know if a PC might be worth the effort...
