1 - 20 of 33 Posts
I'm looking for a set, front and rear for ye old 12r. I didn't realize the stock ones are steel.
I think the rear wheel spacers on a 14 are aluminum. They are a direct swap. When I get to my storage where my 14 is I will verify. The fronts are aluminum but wrong size.
Also, the threaded collars that adjust the engine case to the frame are aluminum on a 14. The smaller of the two is a direct swap for both of the steel ones on a 12.
Thanks CMG, I didnt think about the collars. I believe the cross mounts are the same as those on the 10Rs which can be had in TI. I'll add those 14 collars to the list.
great, more things on my to do list lol. Tell him about the chain adjuster bolts you had on the 1427 Henry
We need a Ti kit like DME sells for the Busa's/1000's.
I understand the ZX14 Left front axle collar is also aluminum
I did read on this forum a long time ago, I think it was Shiphtee that said the A1's had alloy spacers in the front....
I like some of the lightweight options mentioned in this but I still typically fill the front axle with lead on bikes I try to cut weight from lol.
I picked up a few 2017 zx10r parts. The front axle and nut. The nut is aluminum.
The front wheel spacers are aluminum and the same size as a 12. ?
Well thats good...
(I looked them up on a fiche a while ago and was sure the spacers were narrower!)
Well thats good...
Lol now you have me thinking. The parts I picked up are used. But it was a assembled front end. The spacers are the same size as my 12. I went on eBay and did see some listings that look like mine BUT I saw some listings that look narrow....
Hmm.. 25x40x18 dimensions is what I read here and another parts fiche site, hence my reply!
1 - 20 of 33 Posts
