1 - 8 of 8 Posts
Checked the valves clearances today. Stripped the engine bare to get access and followed book and Blitz's procedure.
Exhaust gaps look pretty decent but I was wondering if having a spread of gaps like my inlet measurements is normal. :headscratch:
22000miles B2H.
Measured them all 3 times.
What causes uneven wear?
I think for a massed produced machine like the 12, it seems pretty good.
The difference is so small. That's why the factory has a window of tolerance.
What is the FSM calling for on the intakes?
Book says acceptable intake range is 0.15 to 0.24mm.
So I've a few under gaps under spec and a few right at the top.
How many times hav they been adjusted in the past?
This would be the first time for this bike. I bought it with 6000miles on it.
I guess I should expect a bit of settling in? It just thought it strange that the exhaust side wear is pretty regular and the intake side isn't .
I would be a bit concerned with the small ones. As the valve seats wear the clearance will tend to decrease. You don't want to have no clearance when they expand from the heat.
Shep that is pretty darn good for the first adjustment.
Paul is right, those tight ones need attention.
I think the low spring pressure from the factory helps the longevity. Seat pressure is in the 35-40lb range. Awhile back I was looking to buy a heavier spring. Sal at AcePerformance recommended some 45-48lb springs he had.
Said on a stock engine with a higher rpm redline they would keep the valves in check, but not rob any power caused by a 60lb springs increased frictional losses.
I'm sure 60lb springs would really pound the valves into the head on a daily driver.
Thanks for the replies.
Yes, Ill get the inlets shimmed to the upper end of the spec.
The exhausts are supposed to be 0.22 to 0.31. I recon they aren't worth touching unless someone advises me otherwise.
1 - 8 of 8 Posts
