1 - 10 of 10 Posts
I ended up using 4-330 ohm resistors in front and 6-330 ohm resistors in the undertail but the fron Leds wor fine now!
Thanks for your help!
Roy
Discussion Starter · #5 ·
Vozizm has been doing his homewoek...yes I did take the bump off!
It was very easy the only hard part was figuring out which resistors to solder in line the bring up the resistance so the leds turned completely off and on........but thats been done for you now!
I really like them they are different and slightly more trick than the lp"s
Roy
Discussion Starter · #7 ·
Yes they blink normally...But I installed a heavy duty relay and resistors...very easy to do!
See the pics on the flushmount blinker post or I can Email you some!
Roy
Since I missed out on the group buy, I'll be lookin at the undertail/hugger purchase around the 1st of October. Hopefully I will get my NOS and extensions during the month of September....those signals look pretty nice also...are resisters required for all led installs ?..
1 - 10 of 10 Posts
