Spoke to Pierre a few minutes ago and here is what he said! The "0" Rings 40 MM Inside Diameter and 2 MM Thick (The mounted smaller "0" rings that fit in the throttle bodies!) In shipping by "Air", mounted on the stacks and in the cargo Hole of the airplanes where the temp is "MINUS 30 degrees below Zero" the "0" rings become brittle and in the stretched position, they crack and break!
He is bringing a boat load over here in November (Inside the plane and un-mounted) and in the meantime, he (and I) are looking for the rings here to send to anyone that had a problem! The stacks that were just sent to Orient Express (By Accident) were sent on a boat and should have no problems! Let me know personally if you are anyone you know had a problem and it "WILL" be taken care of!!
Since I do not post on "EasyRiders" Site, it may be helpful if someone transfered this note there!!
I just tried to edit my title and it took a lot less space to fill it up?? What is up with that?? The first time I could state Cracked/Broken "0" rings on Bear stacks Resolved! Then when I got a note and looked, all I saw was Cracked/Broken!! (You only get one chance to get the title correct??
Transfered this over from VICENTHILL @ bikeland
thought it will be usefull....as i'm about to get stacks....
Voz...
http://www.pbase.com/vozizm/zx12r</p>
Voz...
