1 - 15 of 15 Posts
Banned
Define "best"?
Strongest, least amount of stretch, etc. Thanks.
They all stretch in the beginning of use. Most slow and almost stop stretching after a few hundred miles unless they are pure junk. BEST CHAIN is a loaded question... There are many best chains out there to be had that are best suited for particular reasons to a specific task at hand.
BEST CHAIN..
Least rolling resistance = NON O Ring
Strongest = Could be the one with the best materials and heat treating involved or it could the the over sized one that you need to dump for a smaller lighter chain.
Keep in mind that the best chain will only stay at peak performance if it's cleaned and maintained often and drowning a chain with nasty ass chain lube isn't the way.. I believe most here all believe in the WD40 method.. I do and it works like a charm, BUT I stay ahead of my maintenance..
1 - 15 of 15 Posts
