1 - 2 of 2 Posts
Hello there, the problem is from last year: sometimes the bike is not revving good when i open quick the throttle, it's a weird sound like a choke sound(not smooth like it should be), so this weeak i cleaned the carburators and turn the pilots screws to factory 2 turns.
-changed the air filter.
-changed fuel filter.
-checked the sparks.
-last year carbs was sync.
-checked all the hoses.
What else should i do/check ?
Take airbox lid off.
Gently lift 2 carb slides together.
Release, and move one across and repeat and move one across and repeat.
All should close at the same slow rate with a gentle shoooosh.
If any close slightly quicker then that one has a slight air leak under the carb top round the diaphragm. Carefully reseat the diaphragm and carb top, now repeat tests.
1 - 2 of 2 Posts
