1 - 1 of 1 Posts
Hi all,
I installed a Bonneville Pro today and have some issues. I get an Error Code 24 on the bikes LCD If I get hard on the throttle or exceed 110 mph, and I no longer will get a speed reading from the bike's speedo at all when it happens. I can clear the error by reconnecting the ECU wires together and reconnecting the stock speedo sensors as well. Ill drive down the road and the speedo resets and works again. I reconnect the ECU wire bullet connectors to the Muzzy and the speedo sensor plugs back in as well, and the behavior happens again. The box powers on (red LED lights up) and gives me no problems unless Im on the throttle hard or exceeds 110-120mph. I have the dial on the box set to 170. I have the female bullet crimped to the blue/yellow wire going to the front of the bike and the male bullet crimped to the blue/yellow going into the ECU per the instructions. The install is flawless.... Im at a loss.
1 - 1 of 1 Posts
