1 - 17 of 17 Posts
yesterday i went out and brought a vacuum bleeder to bleed the brakes. It will be a stiff brake the go soft. i changed the calipers. the brakes pads are new.i have been bleeding these brakes for the last 2hrs. I need HELP please.
It could be. Try the zip-tie method. If you get a nice stiff lever and then it fades away back into mush I would guess that the master needs a rebuild. I might have a good master for a zx9 I would have to look though.
Tap calipers with rubberr mallet to help air trapped come to the top....be patinet it takes time
Discussion Starter #11
So I got up this morning to ride to work and as I was riding the brake went soft so
I guess it is the master cylinder
Discussion Starter #12
so today i rebuilt my master cylinder and Im still getting a soft brake when im riding. its hard after bleeding then soft before i make it out the driveway
I read your other post before this one so disregard that answer as I'm now going with the magician above as I had the exact same thing happen to me before and its actually the carriers that get warped rather than the rotors themselves, it pays to clean up the disc bobbins every few months to stop them seizing which causes this.
1 - 17 of 17 Posts
