1 - 3 of 3 Posts
Sorry for open a new topic for my problem but i didn't find this kind of situation in other forums.
I have a Kawasaki Z1000 2005, and i have charging problems with it. When i start my bike and measure the voltage on battery there is ~ 10V and it dicrease.. When the RPM is over 3000 or more it starts to increase the voltage to over 14 V.
How can i test my regulator , or if someone else had this problem can help me.
Thank you very much!
Discussion Starter #2
Thank you for reply.
I measured the output ac voltage from alternator. on the all 3 wires comes 30 v on 4000 rpm. In the service manual it says that at 4000 rpm the output voltage must be 42 or more V. So probably that is the problem. I think i will buy another one and i will post the results on forum. Saltimine, what do you think?
thank you
I changed my stator and now everything is OK!
but i have an another question. My regulator becomes very hot after a few minutes. It is a problem or it's normal...
1 - 3 of 3 Posts
