1 - 3 of 3 Posts
Ive replaced my RR , stator core now I'm blowing my 30amp main fuse after running approximately 2 to 5 minutes this happen a few times then my RR from RM stator failed again any one have this issure before
Something is either wired incorrectly or you have added to the electrical system, like lights, etc. Any additional information would help.
I tried PMing you this, but it says you chose to not receive PMs.
Rewire headlights back to factory and replace bulbs with OEM watt bulbs. There is a factory service manual here on the forums you can download.
Shouldn't be too difficult.
I know that when you add LED turn signals, you must have an inline resistor or they won't work. So I think your headlights (LED) were not designed for that system. You would have to wire BOTH headlights back to stock. If you haven't added anything else, like a cell phone charging port, etc, you should be good after replacing the fuse.
1 - 3 of 3 Posts
