1 - 17 of 17 Posts
When I put the bike into 1st gear. My bike stalls while still holding in the clutch lever. Can someone guide me in the right direction. Is it my clutch pack or just need a new cable?
yes, it had a lot of play at one point I watched some videos and shortened up the play to what was in the video. The bike allows me to put it in gear but stalls when I do it
You don't say which model it is as the wiring is different between models.
So, check the clutch lever switch or the diode by the fuse box.
My apologies it’s a 2000 zx12r A1. After my last post I did some further investigating, and found I can put the bike into first gear and back to nuetral without using the lever. I imagine that this is not good. Can you tell me how to fix it
Maybe you forget to put sidestand up lol. Really though could be a faulty sidestand switch. You say "you can put it into first then back to neutral without using clutch lever". Is this while running of while bike is off?
Forget about the diode, on yours you will need to undo the clutch lever mount and remove the clutch switch from the mount. then gently strip apart the clutch switch and clean up all the contacts inside and make sure the 3 dimple contact pad is also clean and still springy.
Sometimes these switches are tricky to reassemble correctly.
Or buy a new one, but even then some are iffy as I've heard of brand new zx12's where this switch didn't work correctly from new.
The zx-9r uses the same switch and I did a picture guide for that here. Clutch switch checking, cleaning and/or replacing. - ZX-9R.Net
  • Like
Reactions: Cal Thorsen
I can switch it while the bike is running and not running. The side stand was up as well. I will check the Lever and cleaned the diode
There is only a diode in the B3 onwards It replaces one of the contacts in the clutch lever switch, that's one of the reasons I needed to know what model you had.
  • Like
Discussion Starter #10
Understood, I cleaned all contacts. Checked the side stand connections for power/resistance. Still doing it. So I left it in 1st gave it a rolling start and it ran fine. Rode it down the block and back, put in in neutral using the lever and back into first and it didn’t stall
Nicely done, you must be pleased of a cheap and easyish fix. :)(y)
That's fairly normal for most Kawasakis. its to let you know you've put it into first.:giggle:
  • Like
Sounds like the clutch cable needs to be adjusted but not up by the lever. At the bottom by the engine.
Discussion Starter #15
So I am starting to have the same issue again. I took the side stand off. Cleaned the diodes and even disconnected the switch so it’s always in the up position. And it still stalls going into 1st. If I start the bike while in first meaning as it’s starting the bike is moving it works and no issues. Is this actually a clutch issue
Strange I can only think there is a short to ground/frame on the Green/white wire going up to and into the Fuse/junction box, or something strange happening in the fuse box.
It does sound like the bike thinks it's in gear with the side stand down.
If you disconnect the switch it's always in the DOWN position or open circuit. When the stand is up and the switch is functioning properly, it will be a closed circuit. The bypass plugs are pretty cheap and easy to come by, or just solder the wires together.
1 - 17 of 17 Posts
