1 - 8 of 8 Posts
This is a kit I have pieced together, but it has everything you would need, plus bunch of extras. What is included.... 3 dynotune nitrous solenoids, 3 stainless steel AN lines (two short/one long), poly line with proper fittings, 3 relays, a WOT activation switch with bracket, two master arm switches, a poly line 1-2 junction, two 90* nozzles, three jets from Dynotune for 20-30-40hp plus an extra jet in the solenoid currently that was supposed to have been 55hp, two nitrous bottles (blue 2lb NOS and silver 2.5lb *not sure on brand* that I installed a siphon tube and new valve in), liquid filled TNT nitrous gauge, all the fittings you need plus some extras.
The way I was going to run this kit: bottle mounted in rear, long AN line from bottle to the solenoid up under the tank, poly line from solenoid to the 1 into 2 junction, then poly line to the two nozzles-each one in the ram air tubes. With the dynotune solenoids the jets are in the solenoid, so one jet is all you need. With the nozzles in the ram air tube it helps mix with the incoming air better before it reaches the air box, a proven method. My only suggestion would be a RPM operated window switch for safety, but it is not required.
I would need to get $275/shipped.
And since everyone likes pictures...
Discussion Starter #2
OK found something else I really want to buy... $225/shipped for a limited time!
sorry for the late reply... but no... i sold all the bottles and kept the solenoids for a later peoject!
1 - 8 of 8 Posts
