1 - 1 of 1 Posts
i asked how to install these a couple weeks ago and no one seemed to know how to install these. i finnally figured it out. i will update with pics later.
DYNA SHIFTMINDER AND SHIFT LIGHT INSTALL.
ITEMS NEEDED
Dyna shiftminder & shift light
Razor
Electrical tape
Soldering iron
Solder
velcro
20 minutes of your time.
Step one:
You remove the windscreen by taking the 6 screws on the windscreen out and just
pull the windscreen off.
Step two:
I unplugged the connector from the back of the gauge cluster and removed the
gauge cluster. There are three bolts that hold the gauge cluster in place.
Remove these bolts and the cluster comes right out.
step three:
solder the wires together.
Green wire - light blue
Brown - connect to shift light
Red wire - brown & white
Black wire - connect to the ground from third light
Step four:
Mount the shift minder box. I mounted my box on the fairing brace with the
Velcro.
Mount the shift light. I used a bracket and mounted it to one of the screws that
holds the front fairing.
this is it.
1 - 1 of 1 Posts
