1 - 3 of 3 Posts
Any of you guys know which is the best wire to receive the speed signal from and where its located? I've used the crankshaft speed sensor on the right side of the engine, but when trying to get the pcv to learn the gears I only get it to see first gear. Was wondering if there was a beter cable to use
The gear position switch is down by the counter sprocket. It’s plug is under the bottom part of the tank. If you have a factory manual, then you will be able to trace the wires you might need at the ecu.
1 - 3 of 3 Posts
