1 - 5 of 5 Posts
Hi all,
Had a weird problem with my A1 12r, was going down the motorway and everytime i hit a bump the engine would cut out, then kick back in again, it did this for a while, but in the end it went from engine cutting out to engine and electrics, until eventually over one more bump the whole thing cut out, and wouldnt turn on, no electrics, nothing!!! It was raining at the time, but i'm stumped. She starts now but occasionally over a bump the engine will cut out and kick back in again. Any ideas, someone said it could be water in the stator!!!! im more to a loose connection, but would it cut both???:crazyloco:
Thanks all
check both leads on the battery also.......do you have a power commander
As above mine came slightly loose and gave similar problems, mine did it when trying to start her, replaced the stock pins with some slightly longer stainless cap heads; by the time I had added my Optimate and heated gloves to the battery the stock pins were a bit too short.
Starter solinoid terminals loose. This is on the battery tray.
1 - 5 of 5 Posts
