Does this mean all is well?
Yes, all is well... Kind of...
Page 2-50. Thanks, drp/Dave.
Follow creed's dlr code 2. Thanks, creed.
Page 2-53, top of page. Read it and weep. Thanks, 02, but you might have a later manual?
_______________________________________________________
... Goes like this. You brought up the pig because? Because the bike does not start? Or you just wanted to read a code, or the bike had a code? Dlr 1 says, my light stays on, I am codeless. Dlr 2 says, read it and weep time?
Time? I have no clue when 'vanish' is leaving you high and dry? So did you have a "phantom" code, too many key fob rides and there you go = Vanished!
Withatsaid, the next time the code comes on, your first step [off to the side of the road] is:
1. Key off. This saves the code.
2. Key on. This is the fast look is to just ground the wire.
3. Key off. You already found zip in dlr 1. Off resets that tapping of wire.
4. Key on. And this is all when it occurs, because right now, vanished is in dlr 1, for argument sake. This is for all the marbles you tap your heels 5 times the light fandango and hold to ground on the 5th count = Good Luck, or it vanished to OZ.
