4
Here's another part-out I have going. Well actually 3 complete part-outs :crazyloco:
I am
PayPal verified since
Apr 30, 2008.
CLICK HERE >>
You can view my ZXF feedback by clicking the image below:
Click on the pic below to view high res photos! Please check the parts/availability list below to see what parts are left. My shipping day's are Wed and Sat.
Windscreen Spikes = $5 (set of 6, 133 available)
05/06 Parts availability/pricing as follows:
Frame = $300 (1 available, clean title, lien sale)
Engine = $700 (SOLD, 5.7k miles, 05 ZX-636)
ECU = $65 (2 available)
Gas Tank = $150 (3 available)
Never Used 15 Tooth Front 525 JT Sprockets = $25 (1 available)
New Vortex 15 Tooth Front 525 Sprocket = $20 (1 available)
Fuel Pump = $35 (2 available)
Gas Tank Cover = $15 (4 available)
Gas Tank Side Plastics = $10 Pair (5 available)
Swing Arm = $35 w/dent, $100 Great Condition, $120 Powder Coated Gold (3 available)
Rear Shock = $75 (3 available)
Chain Guard = $10 (3 available)
Stock Headers = $25 (3 available)
Mid Pipe = $10 (3 available)
Stock Exhaust = $40 (2 available)
Sub Frame = $75 (4 available)
Battery Plastic Tray = $10 (4 available)
Cargo Plastic Tray = $10 (4 available)
Sub Frame Brackets = $5 Each (7 available)
Left Passenger Foot Peg = $20 Each (2 available)
Right Passenger Foot Peg = $20 Each (1 available)
Left Rear Set = $50 (1 available)
OEM Taillight = $20 (
SOLD)
Exhaust Servo = $25 (2 available)
Exhaust Heat Shield = $10 (2 available)
Kick Stand = $25 (1 available)
Complete Key Set = $100 (ignition, gas cap, cargo, 1 available)
OEM blinker = $5 (1 available)
Horn = $10 (3 available)
Radiator w/Fan + Rubber = $90 (1 available)
Fork Tubes = $45 (SOLD)
Lower Triple = $35 (
SOLD)
Rear Caliper = $35 (2 available)
Front Calipers = $65 Pair (2 available)
Speedo = $70 (1 available)
Left Clip-On = $15 (1 available)
Right Clip-On = $15 (1 available)
Headlight Switch Assembly = $20 (3 available)
Headlight Assembly = $75 (SOLD)
Ram Air Snorkel = $FREE (SOLD)
Kill Button Assembly = $15 (2 available)
Radiator Overflow = $10 (1 available)
Chain Engine Cover = $10 (2 available)
Used Grips = $2Pair (2 available)
Rear Wheel w/ Cush Drive + Sprocket + Rotor = $180 (SOLD)
Air Box = $35 (1 available)
Gas Tank Fuel Line = $5 (2 available)
Oil overflow = $5 (2 available)
Throttle Cable Assembly = $20 (2 available)
Rear Axel = $10 (2 available)
Front Axel = $10 (1 available)
Clutch Lever = $20 (2 available)
Stunt Cage = $70 (SOLD)
Front Fender = $20 (1 available)
Front Fender Sides = $5 (3 available)
Headlight Plastic = $5 (1 available)
Left Side Seat Plastic = $10 (1 available)
Right Side Seat Plastic = $10 (SOLD)
Mid Pipe Heat Shield Plastic = $10 (SOLD)
Exhaust Heat Shield Plastic = $10 (1 available)
05/06 Engine Parts availability/pricing as follows:
Upper Casing = $90 (1 available)
Lower Casing = $90 (1 available)
Crank = $80 (SOLD)
Pistons + Rods = $80 Set of 4 (1 available)
Generator Rotor = $50 Set of 4 (SOLD)
Wiring Harness = $75 (3 available)
Starter Relay = $10 (3 available)
Starter = $30 (2 available)
Junction Box = $20 (2 available)
Stator = $3 (
SOLD)
Stator Cover = $15 (
SOLD)
MAP Sensor = $10 (2 available)
Sub Throttle Sensor = $30 (2 available)
Throttle Bodies = $40 (2 available)
Oil Pump = $10 (2 available)
Motor Mount Bolts = $5 (5 available)
Oil Pick Up = $5 (2 available)
Oil Pan = $50 (1 available)
Transmission = $50 (SOLD)
Cam Chain = $10 (2 available)
Rectifier = $20 (2 available)
Clutch Basket Assembly = $85 3k miles, $35 ?miles (2 available)
Water Pump = $10 (1 available)
Pulser Cover = $10 (2 available)
Scratched Clutch Cover = $10 (1 available)
All Hoses = $2 Each (10 available)
Engine Bolts = $30 Lots and Lots of them (Too Many available)
Idle Cable = $5 Each (3 available)
Shifter Rod = $5 (1 available)
03/04 Parts availability/pricing as follows:
Windscreen = $7 (1 available)
Damaged Ram Air Snorkel = $5 (SOLD)
Ram Air Screen w/Rubber = $5 (SOLD)
Center Plastic Support Below Radiator = $10 (1 available)
Fairing Stay = $20 (SOLD)
Left Rear View Mirror = $8 (1 available)
