Just turned on my baby and notice the F1 fuel injection indicator light was flashing. What does this mean. I have the manual, just being lazy and want to hear it from the experts.
OBB
it blinks a code then you read the book as to the exact trouble code then you fix according to the book.....
Basically at some point your ging to need to open that book :p
Do you still have ignition? Can you hear the fuel injectors on switching the ignition on?
I've only experienced this once, and the bike was completely immobilised – turns out the cam position sensor was at fault: an easy replacement since you don't even need to remove the fairing panels but it was a real bastard to diagnose.
Good luck.
She still switches over. In fact I think I fixed it. I adjusted my idle and when I restarted the bike it was off. Hasn't come back on since. So hopefully, it was just telling me I had my idle set too low. It was right about at 1, I adjust it to 1 1/2.
