1 - 2 of 2 Posts
I have a 2000 zx12 with about 9,000 miles on it. I recently installed Full Akrapovic exhuast. Bike runs great, but I noticed when cruising in 6th gear with rpm loping at about 3400rpm to 4000 rpm sometimes the Fuel Injection Light would come on. So I thought well maybe the Stock ECU was having difficulty calculating the correct Fuel \ Air mixture so I intsalled a Power Commander III with the default Akrapovic map w\ stock air filters. Well damn if that light didnt come one again when cruising in sixth a couple days ago. Now it only stays on for maybe 2 or 3 minutes then it with cut off. Also if i downshift and up the rpm's the light with go off. So I put it to you oh wise ones..... any ideas or suggestions.
Thanks in advance fellas.
check your fault codes in your ecm.
1 - 2 of 2 Posts
