1 - 20 of 36 Posts
Does anybody know of a good product to clean the injectors? I can't get the engine to start on my Ninja and I suspect the injectors might be clogged or dirty.
Seafoam x3.
Dunno bout the ingestion part tho...:headscratch: Lemme know how that works for ya...:lol:
worked for F1....
I dunno. It should work. Hell, to decarbon a motor you can just mist water down the neck and let it soak in. Ya get the same effect I guess as using the Seafoam. I've never tried it, but the old race car drivers I know laugh when I talk about spending any kind of money on that project so...Prolly not the way to clean your injectors tho...
And the main ingerdient in SeaFoam is........wait for it.......
Toulene!!!!!
Available in most hardware stores.
But I'm not suggesting you pour a can of that into your tank.....
not quite the main, but its in there.........
Ingredient #............................ 01
Ingredient Name......................... N-BUTYL ACETATE
Percent................................. 10
Ingredient #............................ 02
Ingredient Name......................... ETHYL 3-ETHOXYPROPIONATE
Percent................................. 15
Ingredient #............................ 03
Percent................................. < 5
Ingredient #............................ 04
Ingredient Name......................... ALIPHATIC ISOCYANATE
Percent................................. 45
Ingredient #............................ 05
Ingredient Name......................... MINERAL SPIRITS
Percent................................. < 1
Ingredient #............................ 06
Ingredient Name......................... C8&10 AROMATIC HYDROCARBON
Ingredient #............................ 07
Ingredient Name......................... DISPERSING AID
Ingredient #............................ 08
Ingredient #............................ 09
Ingredient Name......................... XYLENE
Ingredient #............................ 10
Ingredient Name......................... METHYL ISOBUTYL KETONE
Percent................................. 35
Ingredient #............................ 11
Ingredient Name......................... ANTI FLOAT AGENT
Ingredient #............................ 12
Ingredient Name......................... FLOW AGENT
Percent................................. < !
Ingredient #............................ 13
Ingredient Name......................... METHYL ETHYL KETONE
Percent................................. 5
Ingredient #............................ 14
Ingredient Name......................... ANTI MAR AGENT
Ingredient #............................ 15
Ingredient Name......................... ETHYL BENZENE
Percent................................. < 0.1
Ingredient #............................ 16
Ingredient Name......................... TOLUENE
Ingredient #............................ 17
Ingredient #............................ 18
Ingredient Name......................... DIBUTYLTIN DILAURATE
Ingredient #............................ 19
Ingredient Name......................... 2-4PENTANEDIONE
Hmmm, so mineral spirits, MEK, and Xylene(bolded) are all in there as well. All products you can find on the shelf in Home Depot...
Interesting that ALIPHATIC ISOCYANATE and the ethyl-3's are the most abundant ingredients. Now, I've got to find out what the hell N-BUTYL ACETATE is. sounds like nail polish remover.:rotflmao:
I've heard of a product called seafoam?, well I think that's right. Check it out some say it works pretty well, I don't know exactly what's in it, but who cares, its going in an engine and not your body.:nana:
:lol::lol: Have you tried SeaFoam?? :lol::lol:
On the other hand; look into SeaFoam - Or SeaFoam might work... :lol::lol:
I would try SeaFoam, I think... :thumbup::thumbup:
Sorry Pud, I'm weak... :lol::lol:
I`ve used Seafoam with killer results...
I`ve also used Berryman`s B-12 CHEMTOOL fuel treatment and inj. cleaner....Real strong shit...Removes moisture in the fuel also...With all the Methanol/ethanol in our fuels now and the way they attract moisture,ya really need some kind of treatment to keep it in check....Lucas is great too and has a topend lube to it also...
i would say pull your throttle bodies and take the injectors out and soak them for a day in seafoam. then put them back in with seafoam in tank and see if it gets any results. not sure which ninja you got but on a 12 it takes about 30 min to pull throttle bodies out
Could use Seafoam too....
1 - 20 of 36 Posts
