My 03 zx12 Is flooding the cylinders with fuel and getting about 9 MPG.
I just did a full rebuild and here is the basics...
1278 cylinder kit, port and polished head, power commander, Muzzy full exhaust, fuel injectors cleaned and flowed, degreed cams, ignition pickup modded, K&N.
I threw a rod 2 years ago and Built a 2001 block. Using the Muzzy system map till i can get it broken in and tuned. I have not had it above 6K RPM yet. It loads up at partial throttle in any gear. If i am constantly accelerating it runs ok and ides fine once it warms up.
I can't figure out why it is dumping fuel. Fuel pressure is 42psi. I tested the tps and tried a different one as well. Any help would be appreciated
uzzled:
