I just bought a 2001,
I have diagnosed the fuel pump used a positive wire & negative wire on batt terminal and it works fine, fuses are all good the ones on the battery tray and the few on top of the gas compartment. Relay fuse is good tip over switch is good, what could it be?
Bad relay?
Has 3 connectors on the fuel pump terminal, 2 negative & one positive ? Can i hook it direct if so will it flood?
Check side stand switch and clutch switch
  • Like
Reactions: Dave Smith
