So in hopes of finding my electrical prohibiting my PCV from getting a proper rpm reading, I have gone through various connectors of my bike measuring voltages, what has me puzzled is the white red wire voltages which powers the injectors, fuel pump relay, and fuel pump is showing some odd readings. Now with my fuel pump connected my fuel pump relay indicates 12.3 V at the W/R and even slightly less at the fuel pump connector. The W/R wire shows 12.08 at the ECU, however whenever I disconnect the fuel pump itself the voltages throughout the system show a healthy 13.0 V at the fuel pump relay W/R wire, fuel injector W/R wire AND the ECU W/R wire terminal (left side of center plug right under a ground wire). I guess I'm wondering if it's possible that the fuel pump itself is causing issues throught the rest of the fuel system in the bike. ECU grounds are all good, power also seems to be good terminal 48 (White wire) shows 13.1 with a drop to 12.8 when priming, terminal 17 (White Yellow) shows 12.4 while priming then 12.97 thereafter (manual specified 12.5V or more when IGN on so I assume this is within spec), additionally I have gotten a second ECU just to rule out a possibility of a bad ECU and the readings are the same. Thoughts or recommendations regarding what I should look for next or check? When doing the fuel pump test with the Y/R to BK/W connectors at the pump I would get a reading of aprox 12.0/11.9 V which is far bellow the actual battery voltage that the service manual says i should be reading however the manual itself has no indications as to what to do with a low voltage reading. Any help is appreciated
