I went for a ride this morning with my friend that has a '01 GSXR1000. Did a few roll-ons from different gears, all with the same result, pulled away steadily in all gears, at all RPMs. I would have to say its noticeably faster with the full Yosh header than with the slip on. We did a few races before and we were very close although I would pull on him, but now, its not nearly so close. Now here is my question. I have a 200 series tire, 16t front sprocket and a 46t rear. I have the yellow box set at 14.25%, I just don't have a GPS to check my speed with. I tested it against one of those stationary radar boxes the cops put on the side of the rode at 75mph and it actually read 1mph slower than the radar. Then, I checked my speedo against his. His read 90mph, mine read 86mph. Then we did a few high speed runs. He topped out at an indicated 181 on his speedo although it was only for 5-6 seconds at that speed. He said it wouldn't climb any higher. Then I did a run. I hit an indicated 180mph at 11,100 RPMs and it was still climbing quickly, I was running out of room and had to get out of it. At the rate it was climbing, I would have easily hit redline(11,500) or above. By the way, my friend was following and he said he was reading 177mph and I was pulling away fast. So how close is my speedo? I can't help but think its got to be pretty darn accurate. Does anyone else have this gearing setup and have you measured it with a GPS? Do I have my yellow box set up with the right amount of correction?
