Bearing sealed side face?
  • Seal side outward (feeding the input shaft but blocking oil pressure from entering the bearing
    Votes: 0 0.0%
  • Seal side inward (feeding oil pressure to the input shaft and the bearing)
    Votes: 1 50.0%
  • Dont know good question
    Votes: 1 50.0%
  • Its complicated
    Votes: 0 0.0%
  • Total voters
    2
1 - 2 of 2 Posts
I bought a junk 02 klx300r. .. One problem led to another to another to another. So far ive got the head resleaved,piston fittied, rings filed, new valve rod seals, valves seated, shims replaced, professionally cleaned inspected and even ported my intake a little.. So the topends done.
I'm reassebling the bottom end and installing new bearings and seals throughout the case. Ive run into a thinker and ive installed this bearing the way it was removed(which was sealed side in) but im second guessung myself bc its oil fed and mayby This bearing needs to be oil fed? I want to be sure before i continue.. Any thoughts?
1 - 2 of 2 Posts
