1 - 1 of 1 Posts
Hello.
The clutch doesn't release fully, i have tried adjusting the wire and changing the oil.
In the first picture clutch lever is at rest, in the second picture clutch lever is fully pressed. The angle of the clutch actuator arm seems a bit off, its almost in line with the cable, does it look right?
The clutch releases when i help turn the actuator arm a bit more by hand.
What can cause this? If it was the oil or grooves in the clutch basket then it shouldn't help turning the actuator arm extra, or am i missing something here?
The clutch doesn't slip. Please help!
1 - 1 of 1 Posts
