I have a 95 zx-9r that I upgraded the signals to led front and rear after I installed them I tried them out and all for blink simultaneously. Checked the wiring to make sure all were correct and they are but to no avail then I thought the stock relay may not have had the correct resistance so I bought an aftermarket led flasher relay only to still have the same problem. CAN ANYONE HELP THANKS.
I believe this has something to do with the instrument cluster circuitry. I had similar problems with 80s bikes and LEDs. You can either use load equalizers or disable the flasher indicator light on the cluster.
(Update)
Thanks for the ideas I actually had to put resistors inline, one for the left and one for the right side. Fixed problem immediately. Again thank you for the suggestions and ideas.
