Fitted lower pegs, they're great!!! Prob is the brake pedal is slightly higher than peg now and getting in the way, any method of lowering this or just junk rear brakes altogether? Cheers
At the back of the rear brake lever is a threaded rod and lock nut going up to the cylinder. Unlock the nut and wind the thread to shorten the travel and the front end of the lever will drop.
You'll need to get the heel plate off for access I think.
And make sure you adjust the brake light switch after you adjust the rear brake lever!
