1 - 9 of 9 Posts
does anyone have a map they would share with me for an 02 zx12r with full muzzy exhaust and k&n filters? i am using the one on the dynojet website and it kinda sucks, its dead till around 3k rpms then it goes (like when i am trying to turn a corner mellowly at a stop light) also it kinda girgles at certain rpms and pops when i let off the gas. Thanks, Dennis
Discussion Starter · #3 ·
dang, cant get any of those to work, i tried zx9's improved map and when i download it it doesnt show any numbers or anything.....just a blank table.
Thanx for the info,
I'll check the files
Thanx Dave.
I've checked quite a few of the maps,
And it appears that some of them have no 'data',
It may be to do with Power Commander software versions,
I will look into it further,
Thanx Dave.
You will likely find that with enough work you can somewhat minimize the famous low rpm Muzzy "flat spot". But it is a characteristic of the exhaust. Muzzy will probably email you a map if you call them; it used to be posted on their site. Unfortunately, even the map that Muzzy supplies has a horrible flat spot 2500-3k rpm.
1 - 9 of 9 Posts
