Looks like I won't be getting a custom map made until spring, so
I need a map for my new Micron. I have the Yosh EMS hooked up with zero map installed. Does anyone have one out there?? I can use a scanned copy of a map from a PC3 and I could use it and write a new one on the EMS. Anything would be a huge help.
map
Hey Ron,
I found a map for a Micron serpent exhaust on an '02 model with and without an aftermarket air filter. It is for a PCIII but I could convert it over to the Yosh EMS format and add some changes that will prevent backfiring after coming off heavy throttle. Do you want it and do you have an aftermarket filter? Do you want the timing changes too?
Kevin...you are da man!! yes, I definately want it and with timing mods too. I can play with it after I try it. I do not have an after market filter but will have a BMC before spring.
Could you scan the map and send it e-mail???
[email protected]
Thanks kevin...much appreciated
