I have been having charging issues I have replaced everything short of the flywheel . bottom line is my bike is eating batteries is this my stator , fly wheel or mr my RR
I have acquired a 03 stator and flywheel oem stator cover the 03 puts out 4 amps less at 31 amps the 01 puts out 35 amps
Is this 4 amps enough to cause problems
Should be common sense. If your system is 34 amps and you replace it with a different year model that is 31, of course it will cause trouble. Too much load on the system.
it will be fine. the later years with the smaller charging system had basically the same stuff drawing power with an extra rad fan..
