1 - 9 of 9 Posts
Hi, all. New to the group here. I have a 2001 zx12-a2 needing an ecu and all I can find is 2000 a1 model ecu and 02-05 b1 and b2 series. The 02-05 ecu plug ins look the same. But the 2000 model does not. I know the 2000 model is unrestricted and was changed to the a2 in 2001. My question is, does anyone have an 01 model ecu or does anyone know if the 02-05 model ecu work and will I have to change the harness. Im at my wits end with this bike. Any and all help will be appreciated.
17277
17278
17279
01-03 are the same I believe. The 04-05/06 are different. 01-03 32bit processor compared to 64 bit.
The 04-06 have secondary throttle butterflies to control.
I'm not sure about the cam position sensor pick-up angle on the B1/2, and I know the A1 and A2 are different.
01-03 cam position is the same
00 and 04 05 are another position
the ecus are different between 01 and 02 03 even though the pin out is basically the same. 04 05 is another ecu again
1 - 9 of 9 Posts
