1 - 14 of 14 Posts
I have a 00 12. The other night I was leaving hooters and my headlights would not come on. All my fuses are good, I tried my friends junction box thinking it was it but it was'nt. Any ideas what it could be. I would appreciate any info.
Moderator
did you swap bulbs? sometimes its the simple stuff. I had super-white lights and they both shit the bed.
Dead stator, or possibly the headlight relay, or the headlight fuse that is in the battery box. Start with those ideas. Work it 1 thing at a time though.
Since your headlights failed to "come on", instead of failing under power, my vote is the headlight relay... I think there may be 2 relays in that circuit... 8) 8)
+1
If all else fails, go back into Hooters! Plenty of headlights in there! :lol:
There is a fuse in the battery box !!!! Mine did this a few yrs back and took me forever to figure it out.....have no clue why they would put a fuse there when all the others are under ur fake tank ????
+1
Excellent point! :twisted:
Discussion Starter #11
No luck. Tried both relays and the headlight fuse in the battery box. My headlights are not blown. I wonder if the high beam low beam switch could trigger any of this.
"Tried both relays", not sure what you mean by that.
I think he did ZX. Your next step (if you're electrically inclined) is to bypass the relay in the junction box. You'll need the wiring schematics from a shop manual...
Doubtful that the switch is the culprit.
1 - 14 of 14 Posts
