1 - 12 of 12 Posts
designed for nitrous applications onEFI motorcycles. This TPS switch allows the "OLD MICROSWITCH AND BRACKET CRUD" to get tossed. This unit hooks directly to your TPS switch and is easily adjusted. You can determine at what throttle position the switch activates. Once the wires are connected you will hold the throttle in the desired activation position and adjust the switch until the light comes on. It has coarse and fine adjustment for you pickey peoples. Once that is done your are ready to connect to your solenoids or controllers...whatever. Digital circuitry and comes with a 1 year warranty. WORKS FOR ANY EFI BIKE!!!! ZX12, busas,1000.you name it it does it! no more worries if the bracket bends or if the switch is going to rattle apart.
159.95
909-888-8057
wayne....contact me at 909-888-8057 about the switch. Ill post a pic in a bit.
easy---yes Im interested...emial the info at [email protected]
we are slowely building up a zx12 line of goods.
I thought I read in the prostar rules for street bike shoot out class no throtal activated NOS would this fell into this catagory
It takes the place of a wot switch, like the one thats comes in a NOS kit.
1 - 12 of 12 Posts
